LabWindows/CVI
Custom control: slider with two needles
I've been using LabVIEW for some years, and I was able to create a lot of custom controls.
I know that CVI is doesn't allow me such a level of customization, but I don't know if there is a simple and effective way to create a slider controls with two needles (based on the Vertical Pointer Slide for example).
I used two different overlapped slides, and they behave more or less as I expected (not fully satisfied, but ...). I need placing a lot of these controls in a panel, so I wonder if I can group the two slides in a custom control, and write some c code to interface with them (if I select Create >>Custom control, I can't select two different controls...)
Is there another way to create a slider control with two needles?
Vix
In claris non fit interpretatio
Using LV from 7
Using LW/CVI from 6.0
(4,705 Views)
did you consider building your control externally (LabView??) and then use it as an ActiveX control element in CVI?
(4,688 Views)
Is there any available documentation on how to do what you suggest?
Vix
Using LV from 7
(4,685 Views)
Well, this comment consists of two steps: creation and usage of the ActiveX control.
For the latter there are several examples available in the CVI distribution, but I cannot assist in how to create such a control in LabView - From your post I assumed that you have designed (or knew how to design) a suitable control in LabView - and I thought that it should be possible to export it, however without any clue of how this might be accomplished in reality. All I am aware of are the examples in CVI using such controls, e.g. the 3D graph...
(4,680 Views)
Yes, I know how to design such a control in LabVIEW, and I think I can learn how to use it in CVI.
The problem is that I don't think a LabVIEW control could be exported as an ActiveX control...
Vix
Using LV from 7
(4,677 Views)
Hey Vix -
While I agree it's not quite as straightforward as LabVIEW, you can do exactly what you're talking about with LabWindows/CVI.  The basic instructions to do this are here.  Another good resource is to check out the installed custom controls in <CVI>\toolslib\custctrl, and copy their format.  It sounds like for your particular case, you'd want to create a custom control for a slide control.  Then, in the API for your custom control, you could have a convert function that programmatically created the second slide control for your second needle.  If you need more detail than this, let me know.
NickB
(4,673 Views)
If you ask me, I would say there really should be something like an online video tutorial about CVI custom controls.
I myself struggled with it and I do not remember coming up with something useful.
I found the process -as explained in the link Nick provided- unintuitive and hard to control.
It was kinda disappointing for me.
S. Eren BALCI
IMESTEK
(4,668 Views)
