LabWindows/CVI
Cut and Paste with Password Control
If you paste (ctrl-v) information into a "Password Control" field from the 'toolslib' the text is not masked with the desired character.
Pressing 'Enter' with pasted text results in no entry.
Is there a way to modify this behavior?
(3,703 Views)
you are right, looks like the control does not behave correctly when the data is pasted to the control. I'll submit a report on this. In the mean time, you can modify the code to take into account this special case. You can find the code at C:\Program Files\National Instruments\CVI70\toolslib\custctrl\pwctrl.c
Another option is to create a callback for the control and catch the keyboard events; check if the user pasted something and probably swalow the event by returning a non-zero value; this should avoid the text to be pasted.
I hope this helps.
Juan Carlos
N.I.
(3,703 Views)
I ended up creating a work around by looking for the CONTROL key being pressed using the Windows SDK "GetKeyState(VK_CONTROL)" in the EVENT_VAL_CHANGED case of the controls callback.
Since I had been saving the password as each character had been entered (via EVENT_KEYPRESS) it was easy to catch the CTRL keypress and then write the password back to the control and thus wiping out the "Pasted" text. If I hadn't saved the accumulated password I could have 'ate' the event by returning 1 from the callback (at least I think thats how you eat an event).
I had to use the Windows SDK function because LW/CVI doesn't like you probing for keys with "GetKeypressEventVirtualKey()" in the EVENT_VAL_CHANGED case.
The Paste (ie .. the CTRL-V) key sequence didn't pass thro
ugh the EVENT_KEYPRESS case, only EVENT_VAL_CHANGED.
Since I'm really green; I didn't easily find another LW/CVI function that could capture the CONTROL, SHIFT, MENU or ALT keys being pressed.
Thanks for the help!
(3,703 Views)
That is a very good workaround. CVI provides the function GetKeyPressEventVirtualKey (eventData2) to check for virtual keys. however using hte SDK function should do just fine.
good luck with your project.
Juan Carlos
(3,703 Views)
