LabWindows/CVI
DAQmx Error -200288
Has anyone gotten this error?  I am using 2-PCI 6534 cards with CVI and it seems to be a completely random error.  I can run it 100 times and not get it then all of a sudden it will pop up every try then go away and come back after 150 or more.
(3,192 Views)
Nivled,
Can you give a brief description of your application?  Are you trying to synchronize digital input or output on the two boards?  Is it a finite or continuous task?  Are you using any triggering?  This information will help to narrow down the source of the error.
The only other reference I found to error -200288 when writing to the PCI-6534 was the following discussion forum post:
PXI-6534 rewriting IO buffer with DAQmx causes error -200288
Again, if you could provide some information about your application, this will definitely help.
(3,169 Views)
