LabWindows/CVI
DAQmx continuously update output array from example
I am using the example Synch_AI-AO in the DAQmx folder and it works great for sine waves, pulses, triangle waves or anything periodic. However, I would like to output a noise array which is generated from the WhiteNoise function, which is continously updated every N seconds.
I have tried calling the StopCallback then the StartCallback after delaying for N seconds, but since I have to be in function when I call these callbacks I end up getting back to the place where I called them before exiting them (like recursion), which kills my program.
Is there a way to update output so that it doesn't cause the recursion issue that locks up my program?
Thanks.
(4,580 Views)
Accepted by topic author EricJR
Hi EricJR,
Rather than calling the StopCallback and StartCallback functions, have you tried calling the DAQmxWriteAnalogF64 function every time new samples are generated?
Julia P.
(4,512 Views)
