LabWindows/CVI
DAQmx functions for SCXI
I'm quite a beginner on CVI and I hva got some question about DAQmx for SCXI.
Firstly, I have to convert a CVI 5.5 program to CVI 8.1. The fact is that there are some functions that I don't find in DAQmx like:
SCXI_load_config
SCXI_set_config
SCXI_set_gain  => I've found this  " DAQmxSetChanAttribute with Gain in attribute" but I'm not sure it's equivalent because I've to pass  a TaskHandle.
SCXI_reset
Is there an equivalent of these functions?
Thanks a lot
james
(3,715 Views)
I've search more further and I don't know how to configure my scxi chassis!!!
Nobody uses SCXI with DAQmx under CVI 8???
thanks
(3,683 Views)
Did you try to open one of SCXI examples? You can find them by openning the NI Example Finder in LabWindows/CVI: clik on 'Help' menu, then 'Find Examples...' and type SCXI under 'Search' tab.
Cordially,
(3,654 Views)
hi,
there are only 2 examples using  SCXI on CVI8 and It doesn't help me.
But I've solved my problem. I've looked into DAQmx library and finally found the attributes I need to set.
(3,651 Views)
