LabWindows/CVI
DAQmx14.0 in WIndows 8.1
I have 1 computer with OS Windows 8.1 which using to run with USB-6009 & USB-6210.
After tried installing DAQmx 14.0, test panel in Measurement & Automation, found the reading is very slow, comparing Windows 7 or XP with DAQmx 9.1 installed.
May I know how to improve the speed of read & write.
I also tested the program in my CVI program. And I can see the delay in setting value into the panel, column by column. Total of 39x 20 readings need to be set.
This slowness caused the program hang & stopped after few second as not able to capture the
Message 1 of 1
(4,524 Views)
