LabWindows/CVI
DAQmxGetDeviceAttribute
I would to get min and max sample rate my devide (NI 9239) can support. When I try to acquire with a higher sample rate I get the following message indicating the min and max value I desire to get.
I tried with the following code but I get different values.
#include <ansi_c.h>
#include <utility.h>
#include <NIDAQmx.h>
float64 min_rate[1];
float64 max_rate[1];
DAQmxGetDeviceAttribute ("cDAQ1Mod6", DAQmx_Dev_AI_MinRate, min_rate, 1); // min_rate[0] = 1612.903225806451700
DAQmxGetDeviceAttribute ("cDAQ1Mod6", DAQmx_Dev_AI_MaxSingleChanRate, max_rate, 1); // max_rate[0] = 50000.000000000000000
I would to extend the same method to other boards too and I would to use those values in a math formula. Could you help me? Thanks!
(4,014 Views)
I found some documents on the web that explain how to do that. It seems that they are using a diferent DAQmx property:
https://knowledge.ni.com/KnowledgeArticleDetails?id=kA00Z000000P9ypSAC&l=en-US
https://knowledge.ni.com/KnowledgeArticleDetails?id=kA00Z000000P83OSAS&l=en-US
Hope this helps,
Clara
(3,917 Views)
