LabWindows/CVI
DBConnect FATAL RUN-TIME ERROR
The results of the application are saved in the database. The record can be every few seconds or even hours.
The application is resistant in case of problems with connection to the base but not on FATAL ERROR - it appears every 2, 3 days.
Measurements take place in two threads.
Break on Library Errors is off
LW CVI 2015 build Debug64, Win10 Prof.
How to find the cause ? Can anyone help ?
Message 1 of 1
(2,222 Views)
