LabWindows/CVI
DBConnect : SQL Toolkit, test with network shut down
Hello everybody,
I have a question about the SQL Toolkit under CVI.
I must test network connection in my application and all worked well until I simulate a shutdown of network (I remove the network cable of my PC so that my application works in local mode).
But when I plug back the cable, my DBConnect function doesn't work any more properly : its return value is random, sometimes it returns 2, so my application consider that the connection is OK and sometimes, it returns -10 (Connection KO).
Is anybody has a idea of my problem? Thanks a lot
(5,047 Views)
rather than fix the problem it maybe easier to work around the problem.
once you detect that there is no network, stay in that mode untill you have a reboot/restart of program.
you were not clear on how you are detecting loss of network. Are you using the SQL call to determine that.If so do it another way.
Type to open a file that you know is only on the network. In fact place a file in a know place on the network and look for it.
we used a file called "network.$$$"
- Make Software User Friendly -
(5,036 Views)
Thank you a lot, rorOttawa
I think you are right, it would be easier to limit my program in the local mode once the network was removed. We should  restart it again to return in the normal mode.
In fact, to detect network connection, I have a function ConnectDatabaseServer in which I call "DBConnect" using a request: name of the file .mdb + the password.
Then, the return value is used as DB Handle for the following operations. And it is this value which becomes random after removed the cable.
I will test your method immediately, thank youSmiley Wink
(5,032 Views)
You could also ping your server using InetPing command in the Internet library.
(5,026 Views)
by the way ,i only have sql labview toolkt,
how can i get sql cvi toolkit? can i get it by free?
Sonic
Diffrent Strokes for Different Folks
(5,003 Views)
As you can see in this page, the former sql toolkit is now packed together with some other software toolkits into the Entrerprise connectivity toolkit. I suggest you to contact your local NI representative to see if based on your existing software you can get acces to some upgrade offer and / or facility (for example we have choosen to subscribe a Developer Suite which offers several additional toolkits both for CVI and LV)
(4,993 Views)
