LabWindows/CVI
DBGetVariantArrayValue causes error in release.exe
The SQL Toolkit function DBGetVariantArrayValue causes an error if i try to fetch the value of the last column in the first field of an table.
This does not happen on the Developer PC (Win7 x32) but on a Measurement PC (WinXP x32/ Win7 x64) it happens reproducibly.
my code Extraction:
//Get Array of Varriants
resCode = DBGetVariantArray (hstmt, &cArray, &numRecs, &numFields);
if (resCode != -10) {
   int colType[numFields];
   for (int j = 0; j < numFields; j++) {
       colType[j] = DBColumnType(hstmt,j+1);
   //Iterates through the Array of result strings:
   for (int i = 0; i < numRecs; i++) {
	//Because of NULL-values in Database tables
        //"DBGetVariantArrayValue" throws Non-fatal error messages,
	//these are extreamly disturbing for debugging, so we disabled
        // and enabled it.
	SetBreakOnLibraryErrors(0);	//Disable Break on Error
        //Sets results of VarriantArray to strings:
	resCode = DBGetVariantArrayValue (cArray, numRecs, numFields, CAVT_CSTRING, i, j, &tmpVal);
	SetBreakOnLibraryErrors(1); 	//Enable Break on Error
//...Further processing...
 Table from a SQL Anywhere 11 Database:
ID
Date
SerialNr
File
Type
Value1
Value2
Value3
int
UDT_DATETIME
UDT_LABELSTRING
UDT_LABELSTRING
UDT_LABELSTRING
UDT_REAL
UDT_REAL
UDT_INT
1
2011-08-12 12:00:30:50.000
SN1
asdf.txt
yxcv
1,23456789
9,87654321
200
2
SN1
asdf.txt
yxcv
1,23456789
9,87654321
200
3
SN1
asdf.txt
yxcv
1,23456789
9,87654321
200
4
SN1
asdf.txt
yxcv
1,23456789
9,87654321
200
5
SN1
asdf.txt
yxcv
1,23456789
9,87654321
200
Error orcures if my Code tries to fetch Value3 of the first line.
are there any ideas?
best regards
Message 1 of 1
(3,439 Views)
