LabWindows/CVI
DIAdem Connectivity Library And VB.Net
I'm tring to to use the DDC_Create function from the TDM C dll the problem is that I keep getting a -6202 Error (Invalid Argument)
<DllImport("nilibddc.dll", CallingConvention:=CallingConvention.StdCall, CharSet:=CharSet.Ansi)> _
  Public Function DDC_CreateFile(ByVal FilePath As String, ByVal FileType As String, _
                                   ByVal FileName As String, ByVal Desc As String, _
                                   ByVal Title As String, ByVal Author As String, _
                                  ByRef File As IntPtr) As Integer
I have looked everywhere for help and tried every combination of possible solutions that I could think of without luck.  I know that this should work is it is the way that others on this forum are doing it with success, I'm definitly getting frustrated.
(3,559 Views)
I forgot to mention that this is how the code is called
Dim FilePtr As IntPtr
DDC_CreateFile("C:\Temp", "DDC_FILE_TYPE_TDMS", "Test.tdms", "None", _
                               "test", "Author", FilePtr)
to me thats looks good which is why I am thinking that the error message must some how be misleading me.
(3,556 Views)
I posted on your other post in the DIAdem forums.
Jacob R. | Applications Engineer | National Instruments
(3,525 Views)
