LabWindows/CVI
DLL Error Using CVI & Teststand 2019
I am trying to run a LabWindows/CVI dll into Teststand and it showing me the following error: "Could not Load DLL or External Library". I am using Teststand and CVI 2019 tools. I have the dependencies that it needs but it's still throwing this error. It is working on another computer without any issues and I haven't rebuilt the dll. Is there some sort of setting issue in Teststand that is causing this?
Shreya
(1,295 Views)
Not sure if TestStand is available as 64-bit but could it be that one of them is 64-bit and the other is 32-bit? If you create a 32-bit DLL the calling process needs to be 32-bit too. Dame for 64-bit. Caller and callee need to be the same bitness.
Rolf Kalbermatter  My Blog
(1,279 Views)
Hey Rolf,
That's what I thought initially as well so I made sure and both the Teststand and LabWindows/CVI are 32-bit.
(1,256 Views)
I see that all the libraries listed as missing are system components: could it be that you are running on some reduced-configuration Windows system like IoT Enterprise that has been tailored excluding those components?
(1,240 Views)
Couple of things to try:
1. Do you have the correct version CVI Runtime engine installed?
2. Use Depends (Dependency Walker (depends.exe) Home Page) to find out what DLL is missing.
Anand Jain
NI
(1,225 Views)
