LabWindows/CVI
DLL execution time too long
I have a DLL build with Labwindows CVI 2012. A function of this DLL is called by an application which is a sequencer. After the first call, the sequencer executes the function properly. But when it calls the function, a second, third, fourth time, the execution time gets more and more bigger. Can someone understand the problem? Bugs (if there are) are located in the application (sequencer) or in the DLL?
Thanks in advance,
James
(4,447 Views)
Hi James,
It seems that the issue is related to what is done in the DLL.
How did you compile the DLL (Release or Debug) ?
If Debug, did you try to debug the DLL and see what execute in the DLL?
Can you provide the C file ?
Valentin
Certified LabVIEW Architect
Certified TestStand Architect
Certified LabWindowsCVI Developer
National Instruments France
(4,426 Views)
