LabWindows/CVI
DLL use on an other PC
Hello
i wrote a program on an PC. It works.
I pack the program in a distribution und install it on another PC.
I copy the extern dll into the systemdirektion.
It dosen't work correct, but i didn't become a error message too.
Can you help me?
(3,013 Views)
The following cases are typically thinkable for a DLL that may not work correctly on the target PCs, when you have just copied the DLL:
1)DLL is built as a COM DLL, but not "registered" on the target PC.
2)DLL has some dependency to other DLLs (such as 3rd party components), but they do not exist or not correctly installed on the target PC.
3)DLL has some dependency to specific Windows version, but the target PC OS is different.
4)DLL is build as a legacy non-COM DLL but its location is not specified by PATH environment variable.  (This case is not thinkable in your case because you copied the DLL into Windows/System32 directory.)
Is any case matched?
There is a good tool, which checks DLL's dependency.  It may help for your problem.
http://www.dependencywalker.com/
(2,991 Views)
It runs now.
The problem was a forgot file für the dll. It need it too.
Bye
(2,979 Views)
