LabWindows/CVI
DS_GetAttrNames disagree on names[], count
Hey guys,
  Noticed an issue with DS_GetAttrNames() on an RSLinx OPC Server.  Function is returning Success, NumberofAttributes=4, yet Names array only contains a single "Quality" value.  How do I get to the other three?  Or, is my assumption correct that the NumberofAttributes value is incorrect?  I'n using code directly from the function panel help.
Orlan
P.S.  What is the latest DS release?  What files do I need to check?
(2,856 Views)
Hi, Orlan.
Can you post a snippet of your code? Obviously I won't have the server to access, but I'd like to take a look at what you're seeing.
Thanks!
Sarah K.
Search PME
(2,821 Views)
