LabWindows/CVI
DS_Open&DS_DS_GetDataValue Unknown Error
I have an application which uses DS_Open and DS_GetDataValue commands and it works fine on my computer.
I wanted to run the application on another pc by creating a "Distribution kit", but the sw does not work.
I have received unknuwn error at DS_Open and DS_GetDataValue commands in debug mode.
Can somebody tell me want could be the problem?
(WindowsXP, CVI 6.0)
Thx
(3,605 Views)
Hello Raybie,
there seems to be a problem with the DCOM-settings on your PC. Please have a look at the Component Services: To open Component Services, click Start, click Control Panel, and then click Performance and Maintenance. Click Administrative Tools, and then double-click Component Services.
Please check the settings and rights of your COM/DCOM services.
If this doesn't help please post a minimized example here that show your problem.
District Sales Manager
(3,574 Views)
Hi oyster,
The services have been found, but in a different location than you describe (Start,Control Panel, Administrative Tools, Component Services).There are a lot of services. Which one is related to "DS_" functions?
Raybie
(3,532 Views)
Hello Raybie,
please have a look at the hints given in
http://forums.ni.com/ni/board/message?board.id=180&message.id=2110&requireLogin=False
You should ensure that DataSocket is installed on the second PC or to include it to your Distribution Kit (at "Drivers & Components").
To find the correct settings, you should compare both computers and the settings.
(3,525 Views)
