LabWindows/CVI
DS_Open and Microsoft WebBrowser ActiveX conflict?
In the past days I found a problem (or a kind of conflict) between DS_Open function and Microsoft WebBrowser ActiveX.
On my PC (Win XP Pro SP2, CVI 6.0 with a later installation of CVI RTE 8.1) it's easy to reproduce the problem:
- download the dsweb.zip example from here
- if you launch this example everything should work fine
- on the uir add a Microsoft WebBrowser Activex
- recompile the project and run it
- when you  press "Get Web Page" you have a fatal error in RunUserInterface() function
could someone help me?
Vix
In claris non fit interpretatio
Using LV from 7
Using LW/CVI from 6.0
(4,417 Views)
The problem is in dsweb.c. It is incorrectly calling DS_DiscardObjHandle in the DataSocket callback - this causes the DataSocket object to be prematurely destroyed. The solution is to discard the datasocket object outside the datasocket callback - say, after QuitUserInterface.
(4,406 Views)
Thank you very much Mohan; your suggestion fixes the behaviour perfectly.
Now I have another strange problem in my application, that unfortunately is very long and complex...
After I call a DS_Open function I see the following problem:
  • when I call FileSelectPopup() with fileTypeList set to "*.html", I can see the list of files in the defaultDirectory, but the icons aren't the usual Internet Explorer icons: they are the Unknown File Type icons
  • when I double-click a file, I load a new panel with a Microsoft WebBrowser ActiveX in it, but the LoadPanel() function crashes with the fatal "ActiveX error". If I haven't called the DS_Open() before, everything works fine. Even if I call DS_DiscardObjHandle() before FileSelectPopup() the program crashes anyway.
Have you any ideas?
Vix
Using LV from 7
(4,357 Views)
Accepted by topic author vix
I am not sure about the icon problem. You can check how these files look when you open the default directory in Windows Explorer. It is probably a system specific thing - but I am not sure.
About the other problem - I think this is because of threading model conflict. Try calling
CA_InitActiveXThreadStyleForCurrentThread (0, COINIT_APARTMENTTHREADED);
as the first call in main() before any calls to DS_Open or LoadPanel.
(4,347 Views)
