LabWindows/CVI
DSO1012A Agilent SCOPE
Hi Jeff,
When sending "*IDN?\n" using the Test Panel, I get the Model "DSO1024A,CN50209337,00.04.0 ..."
How can I write other comands in this panel?
Message 11 of 15
(1,348 Views)
Hi YGraphPopup,
In this link you can find a basic guide on how to use the VISA Test Panel.
Eric NI
Message 12 of 15
(1,318 Views)
Hi Eric,
The error accur on the viCheckErr (viQueryf (io, ":MEAS:%s? %s, %s", "%le", AG1000NI_VAL_RISING == Direction? "PDE" : "NDE", Source1, Source2, Measurement)); command.
What should I write on the VISA Test Panel Write command?
Message 13 of 15
(1,237 Views)
Hello YGraphPopup,
Please reference your instrument's programmers reference manual to find a list of commands that your instrument recognizes. If "MEAS" is a valid command, try that.
Jeff L.
Message 14 of 15
(1,200 Views)
Hi Jeff,
I couldn't get any response with several strings that I have sent via the Test Panel.
I also got no solution from Agilent that said problem is related to NI driver.
What else can be done in order to make driver work with the Model I have (connect in a remote to my PC!?) ?
Message 15 of 15
(1,059 Views)
