LabWindows/CVI
Daqmx acquisition tutorial
I'd like to find a DaqMx tutorial for LabwindowsCVI because I am a CVI newbie.
Olivier
(4,846 Views)
You will find some basic informations about DAQmx in many languages including CVI in this document: Learn 10 Functions in NI-DAQmx and Handle 80 Percent of Your Data Acquisition Applications
Another useful document can be Using the DAQ Assistant in LabWindows/CVI
These documents can be a basis to help you understand the CVI samples that are installed together with DAQmx and are located in <cvidir>\samples\DAQmx folder. I suggest you to take and execute some of them in order to begin practicing with DAQmx.
(4,836 Views)
 Hi Olivier,
 Roberto B. has made some very good suggestions. Looking at how LabWindows & DAQmx work together can be seen very well in the examples that are installed when you install LabWindows. I would probably start with the examples from the NI Example Finder.
 Have a great afternoon,
 MatthewW
(4,814 Views)
