LabWindows/CVI
Data File Parsing in CVI
Hi guys,
I'm new in LabWindows. I have a simple project, which has to parse a .txt file. Only some data inside the txt-File is interesting (the middle part, segment # 1-3 -> see example). The upper and lower part differs in size and is not important. Are there predefined LabWindows function, which I may use, or do I have to code it in C?
xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx
Program Run:    xxxxxxxxxxxxxxxxxxxxxx                       Model: xxxxxxxxxxx
Description:    xxxxxxxxxxxxxxxxxxxxxx
xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx
                                     xxxxxxxxx
Seg-  Segm.  Run   |  Mix   |  RMV  GasVol   Max   Max     CNS    CPTD    END     END
 ment  Time   Time  |  Used|    liter   Segm.    A     B      %        %     N2      N2+O2
  #   (min)  (min) |    #   | /min  liters  (mswg) Segm.   Segm.  Segm.  (mswg)  (mswg)
  1     0.1    0.1 |    1   |20.00     4.0    20.  0.62     0.0%    0.0     20.     20.
  2    19.9   20.0 |   1   |20.00  1178.4    20.  0.62     2.9%    6.1     20.     20.
  3     2.2   22.2 |   1   |20.00    87.7    20.  0.62     0.1%    0.1     20.     20.
                                                            3.0%    6.2
                                                           Total  Total
                                                  with 1.5
xxxxxxxxxxxxxxxxxxxxx:                 liters     safety factor
                         Mix    # 1    1270.1     1905.1
Message 1 of 12
(5,843 Views)
there is the class of CVI's scanning functions such as ScanFile (, );, which you can find in the Formatting and I/O library; similarly (different, but neither better nor worse) you can use the standard, ANSI C functions such as fscanf (, );
Note that the format strings are different for the two libraries.
Message 2 of 12
(5,839 Views)
Since it is a text file, you could read it in lines, skip the lines you don't need and parse the lines of interest.
The easiest way is probably to use the following Formatting & I/O Library functions:
OpenFile to open up the file in ascii mode
ReadLine to read the file line by line
CloseFile to close the file after use
You will need to iterate on ReadLine in a loop until EOF (return code = -2) and on every line test if you want to parse it or not.
Based on the file contents you showed us it is probably enough an initial loop that simply scans lines until the dashed line is found, next start a second loop that reads and parses the following lines and exits on the first line beginning with 5+ spaces.
To parse the lines you can either use standard C functions like sscanf or CVI native functions like Scan. The online help for the latter offers a good description and several examples for the most common types of scans, while for the first one you can look for help in a good C manual.
Don't forget to close the file after you have finished reading it and to add good error checking to prevent unexpected behaviour in case of I/O errors.
Message 3 of 12
(5,839 Views)
Ok, perfect explanation... Thanks alot!
Message 4 of 12
(5,822 Views)
What kind of error handling do you suggest?
Message 5 of 12
(5,814 Views)
Ok, now I tried to build an Callback-Button, which should open a file and print it in a text box. Unfortunatly it does not work. What did I wrong...
Sorry for my stupid questions...
static int filehandle;
int CVICALLBACK AddCallback (int panel, int control, int event,
                             void *callbackData, int eventData1,
                             int eventData2)
    char str[150];
    if (event == EVENT_COMMIT)
            filehandle = OpenFile ("test.dat", VAL_READ_ONLY, VAL_OPEN_AS_IS, VAL_ASCII);
            while(!filehandle) {
                ReadLine(filehandle, str, 150);
                SetCtrlVal (panel, PANEL_ACTIONBOX, str);
            CloseFile (filehandle);
    return 0;
Message 6 of 12
(5,809 Views)
I would assume that your while - condition never changes and thus you end up in an infinite loop...
You should test for the return value of ReadLine:
status = ReadLine ();
while (status > -1 )
Message 7 of 12
(5,804 Views)
wolfgang is right in pointing you to the while condition error: you actually never enter the while since OpenFile either returns a true handle (>0) or -1 in case of errors!
Going a little bit further, you can test both EOF end error indicator this way:
int  error = 0;
while (1) {
  status = ReadLine (...);
  if (status == -2) break;    // end of file reached
  if (status == -1) {   // Error found
    error = GetFmtIOErrr ( );
    break;
CloseFile (...);
Next you can warn the operator of any error found using GetFmtIOErrorString () to get a short description of the error.
Message 8 of 12
(5,797 Views)
It works very nice...
The only problem I currently have is, that it only prints out every second line????????
                             int eventData2)
    int error = 0;
    int status = 0;
    int filehandle = 0;
    char str[351];
    if (event == EVENT_COMMIT) {
        filehandle = OpenFile("test.dat", VAL_READ_ONLY, VAL_OPEN_AS_IS, VAL_ASCII);
         while(1) {
              status = ReadLine(filehandle, str, 350);
              if(status == -2)
                break;
            // Error found
              else if(status == -1) {
                //error = GetFmtIOErrr ( );
                break;
            else {
                    strcat(str, "\n");
    return 0;
Message 9 of 12
(5,789 Views)
... delete your second call of ReadLine and it should work Smiley Wink
                             int eventData2)
    int error = 0;
    int status = 0;
    int filehandle = 0;
    char str[351];
         while(1) {
              if(status == -2)
                break;
            // Error found
                break;
            else {
                    strcat(str, "\n");
    return 0;
Message 10 of 12
(5,786 Views)
