LabWindows/CVI
Data Socket Distribution
I'm having trouble getting the data socket server to launch on a machine that doesn't have the full cvi development loaded. I've installed the data socket from the cvi\redist subdirectory and it seems to work from the start menu. When I call the DS_ControlLocalServer (DSConst_ServerLaunch) the server doesn't load. I'm using the local host and have set the data socket server manager to all local host settings. I've also tried to set the install data socket switch to always in the distribution creation window. How do we distribute the data socket with our stand alone programs.
(4,020 Views)
Hello Kenny,
Make sure you have also included the cviauto.dll and dataskt.dll from
the windows system directory
in your distribution.
Regards
Rainer Zieschang
Software Development
LEMKE DIAGNOSTICS GmbH
www.ldic.de
(4,020 Views)
Actually, to get DataSocket functionality (server and client capabilities) on the target machine, you only have to select the option to install this in the Create Distribution Kit window. I have attached two zip files to my post, one that has a distribution kit that installs DataSocket support and has an application called "test" that programmatically launches and closes the server, and one that contains the source project for this app. If you want to see what the minimum distribution kit options to choose when making your distribution kit to include DataSocket support are, look at the .bmp file in the .zip file that has the distribution kit in it.
If after installing this distribution kit on your target computer, it still does not work, we will have to se
riously question the integrity of the pc and you might want to try uninstalling all NI software from it, reboot the pc, then reinstall the distribution kit again. If it still doesn't work after that, you might want to uninstall again, run a utility like Microsoft's regclean.exe to clean the registry, and then try reinstalling the distribution once more. Lastly, if none of the above solves the problem you might want to try reinstalling the OS (doing a "dirty" install at first, then a reformat and "clean install as a last resort) and then the distribution again.
Jason F.
www.ni.com/ask
(4,020 Views)
