LabWindows/CVI
Data acquistion after output with double buffer
Is there a way to acquire data that is being output by a double buffer? The code for double buffer is shown below. The way I am getting the data to the input channel is by wiring the input channel with the output channel. Once I have the data already in the input channel, how can I acquire it with CVI?
Thanks.
Message 1 of 11
(4,933 Views)
Try looking at the shipping example "DAQdoubleBuf.C" at: C:\Program Files\National Instruments\CVI71\samples\daq\Ai. It demonstrates how to acquire data from an AI channel.
Please let me know if you have any further questions.
Sean C.
Message 2 of 11
(4,926 Views)
Hi, Sean. I've looked at the "DAQdoubleBuf.c" example with AI and merged it with my code. So now I am supposed to output the data and acquire the input. I have attached the modified code. However, there is a problem when I run the program. when I iterate through the loop "while ((iLoopCount < iHalfBufsToWrite) && (iStatus == 0))", which outputs the data, a run time error is thrown by the "WFM_DB_Transfer" function:
" NON-FATAL RUN-TIME ERROR: "WFMdoubleBuf.C", line 207, col 27, thread id 0x00000544: Function WFM_DB_Transfer: (return value == -10608 [0xffffd690]). noTransferInProgError: No transfer is in progress for the specified resource."
This happens only after I merged the codes for AI and AO.
Message 3 of 11
(4,906 Views)
I was able to reproduce your error. You are right, when I comment out all of the AI code, the AO works just fine. I will continue to look into this and let you know when I have some results.
Sean C.
Message 4 of 11
(4,890 Views)
Thanks Sean.
Message 5 of 11
(4,866 Views)
You might be having problems because you are configuring and starting your AO, and then configuring and starting your AI.
Take a look at the following example which demonstrates how to synchronize AI and AO.
http://sine.ni.com/apps/we/niepd_web_display.display_epd4?p_guid=B45EACE3E72F56A4E034080020E74861&p_node=201223
Let me know if you have any further questions.
Sean C.
Message 6 of 11
(4,859 Views)
Hi Sean, I ran the code and the WFM_DB_HalfReady function threw this error:
" NON-FATAL RUN-TIME ERROR: "AIAO_Sychronize.c", line 141, col 18, thread id 0x00000434: Function WFM_DB_HalfReady: (return value == -10608 [0xffffd690]). noTransferInProgError: No transfer is in progress for the specified resource."
Right after the "SCAN_Start" function I can see on the oscilloscope that 2 waveforms with 2 cycles are output. But then as soon as it enters the while loop the "WFM_DB_HalfReady" function throws the error.
Message Edited by vtech on 06-07-2005 11:49 AM
Message 7 of 11
(4,846 Views)
The following KB offers a solution to error -10608: http://digital.ni.com/public.nsf/websearch/37752A79EB6A950886256C8B006E8870?OpenDocument .
Try turning the regeneration option to ON. To do this use the WFM_DB_Config() function. See the attached image.
If this does not help, try reducing the sample rate. Let me know if you continue to have problems with this.
Sean C.
Message 8 of 11
(4,833 Views)
Thanks for the tip Sean. I was able to run the program without the error occuring.
Is there a way to increase the number of output points? Initially the code only had 1000 output points. But anything over 12000 points will create stack overflow. I was looking at another similar example here: ftp://ftp.ni.com/contrib/epd/B45EACE3E6B856A4E034080020E74861/AO_Change_Freq_and_Amp.zip
and they use 800000 points for their buffers.
Message 9 of 11
(4,824 Views)
The following Knowledge Base describes the error you are seeing: http://digital.ni.com/public.nsf/websearch/9366D2132D82A24586256A120000E57B?OpenDocument .
I was able to eliminate this error by declaring the buffer arrays as static. See the attached image.
Let me know if this does not help.
Sean C.
Message 10 of 11
(4,800 Views)
