LabWindows/CVI
Data types in an union - byte swapping
Hi
I´m using CVI 7.0 and I have a problem with an union type definition in a Modbus application.
I have defined the following type:
typedef union
  unsigned char Buffer[20];
  union
      struct
        unsigned char RegAdrHigh;
        unsigned char RegAdrLow;
        unsigned char NumRegHigh;
        unsigned char NumRegLow;
        unsigned char CRCHigh;
        unsigned char CRCLow;
      }Bytes;
      struct
        unsigned short RegAdr;
        unsigned short NumReg;
        unsigned short CRC;
      }Read;
       }Func;
  }Frame;
}*Query_t;
Serial data are read into the Buffer variable inside the union:
Query->Buffer[i] = ComRdByte (...);
If I access the union with the char variables I will receive the right byte values, but if I access the union with the short variables the byte order is swapped.
For example:
Access to char variables:
"Query->Frame.Func.Bytes.RegAdrHigh"    shows 0x00
"Query->Frame.Func.Bytes.RegAdrLow"    shows 0x01
"Query->Frame.Func.Bytes.NumRegHigh" shows 0x00
"Query->Frame.Func.Bytes.NumRegLow"  shows 0x01
"Query->Frame.Func.Bytes.CRCHigh"       shows 0xD5
"Query->Frame.Func.Bytes.CRCLow"        shows 0xCA
Access to sort variables:
"Query->Frame.Func.Read.RegAdr"       shows 0x100      -> this should be 0x01
"Query->Frame.Func.Read.NumReg"     shows 0x100      ->  this should be 0x01
"Query->Frame.Func.Read.CRC"           shows 0xCAD5   -> this should be 0xD5CA
Can anybody tell my why this phenomenon occur? Is this related to little/big endian?
In the memory display shows that the bytes stored in the right order (0x00, 0x01, 0x00, 0x01, 0xD5, 0xCA).
Many thanks in advance for your hints!
Thomas
(3,721 Views)
Every time I used Modbus protocol to communicate with some equipment I had to swap bytes both for integers and for floating point variables. Here the function I use to treat shorts:
short conv_word_to_short (unsigned char * buf)
 return ((*(buf + 0)) << 😎 +
   (*(buf + 1));
(3,718 Views)
