LabWindows/CVI
Datasocket DS_Open() fails with fatal runtime error
CVI: Version 7.0
OS: Windows2000
I am using datasocket to get data from a device
using HTTP protocol periodically (say every 5 minutes).
DS_Open() fails with fatal run-time error after 1056
cycles and I got the dialog box with following error
message.
Title: ComponentWorks
Message: Error Creating default control
Any idea why this is happening?
Thanks for your help!
Mano
(4,129 Views)
Hello
Is it always the same number of cycles? Do you have some sample code I could try this with on my system. Make sure that you are closing all the datasocket resources by calling DS_DiscardObjHandle().
Bilal Durrani
NI
Bilal Durrani
NI
(4,129 Views)
Hello Bilal,
Yes it always fails after 1056 cycles.
I did use DiscardObjHandle() to close the
DataSocket handle.
I am attaching the sample source code for
you to try.
Let me know about your findings.
Mano
(4,129 Views)
I think this is happening because DS_Open doesnt actaully wait for the connection to fully go thru before it returns. Instead of using DS_Open, use DS_OpenEx to wait until the connection is made, like the following:
hr = DS_OpenEx ("http://www.ni.com", DSConst_ReadAutoUpdate, NULL,
NULL, DSConst_EventModel, DSConst_InfiniteTimeout,
&handle);
So this way, you know for certain that the connection was actaully made before you discard the connection. After making this change, I went upto 1700 cycles and still going strong.
Bilal
Bilal Durrani
NI
(4,129 Views)
Hi Bilal,
Thanks for the reply.
I am still having the problem even if I used
DS_OpenEx().
DS_OpenEx() fails if I set Access Mode parameter to DSConst_ReadBufferedAutoUpdate or DSConst_ReadBuffered.
Please let me know if you have a solution.
Mano
(4,129 Views)
Try changing the Execution model to DSConst_PollingModel.
This behavior does look like a problem and we're currently investigating this.
Bilal
Bilal Durrani
NI
(4,129 Views)
