LabWindows/CVI
Debug Static Library
I have built a static library with LabWindows CVI. I have another CVI
project that links to and calls functions from that library. How can I
set breakpoints in the library? Also, I don't seem to be able to "Step
Into" those functions.
Stephen
(3,263 Views)
Stephen,
You cannot debug static libraries in CVI. Have you considered building a DLL instead? Those you can debug just fine.
Once you have finished debugging your project, you can then easily switch it back to a static library, and that way you won't have to distribute the DLL to your users.
Luis
(3,259 Views)
