LabWindows/CVI
Debug problem
I'd like to do a step over (F10) when I debug my program, but it doesn't working.
When the programm is runnig, it breaks at the first breakpoint and when I press on F10, the programm run until the next breakpoint.
Is there an option?
Is there an install problem?
Best Regards
Panchaud
(4,230 Views)
I've never encountered such a problem (from CVI 6 to 8.5)
Are you sure you're second breakpoint is not in the call stack of the first one?
Nicolas
(4,219 Views)
yes I'm sure.
it's KO with a PC and KO with an another PC. And that with all project.
Regards
Panchaud
(4,216 Views)
What version of CVI are you using?
What OS are you working on?
What happens if you select Run/Step over from CVI menu?
Are your two breakpoints in the same thread?
Nicolas
(4,164 Views)
I use :
- CVI 8.5.1
- XP Pro SP3
It happens the same as F10.
For exemple, if I put a breakpoint at line 8 and another one at line 17(with code between the both, for exemple SetCtrlVal()). When I click on Run the code stopped at
the line 8. After when I click on step over, it happens the same as continue (F5).
I'll try to re-install CVI.
Regards
Panchaud
(4,146 Views)
