LabWindows/CVI
Debugger crashing after F5
You can upload it on ftp://ftp.ni.com/incoming, like you did with the log.
Message 21 of 49
(4,024 Views)
But those files can be downloaded anonymously, correct?  We have sensitive IP clauses here.
Message 22 of 49
(4,022 Views)
Other users can't download the files from ftp://ftp.ni.com/incoming, only they can see the titles.
Only NI folks can download files.
Message 23 of 49
(4,018 Views)
Hello ElectroLund,
you are not alone with this problem.
I have a project with two DLLs from measurment device manufactures already included in the project.
If I include another DLL, written in LabView 2013 the programs hangs after reaching a breakpoint. I cannot continue. This happens all the time.
The position of the breakpoint in my code doesn't matter.  I have tested this with several positions right at the start of the programm or in the middle of a routine.
Same project in CVI2012 has no problems.
I have already created a post with former problems of loading the LabView RunTime-Engine when using that DLL.
http://forums.ni.com/t5/LabWindows-CVI/CVI2013-unable-to-load-LabView-RunTime-Engine/td-p/2590579
Now with CVI2013 SP2 and that DLL, created now with LabView 2013, I am one step further but now having that debugging problem.
My project is really large and I cannot send it. If I can find some time I will try to reduce the project to the minimum and send it.
Gunther
Message 24 of 49
(4,004 Views)
gunthill, very interesting.  I too had no issues debugging with this same project in CVI2012.
This project also has a several DLL files included for an FTDI RS232-USB bridge chip.  I wonder if that's a common link.
Message 25 of 49
(3,992 Views)
Hello ElectroLund and Gunther,
When this hang happens, do you have any special windows in your program, like ActiveX controls or other windows then uirs?
Constantin
Message 26 of 49
(3,853 Views)
Hello Constantin,
I only use uir files in my project.
Best regards Gunther
Message 27 of 49
(3,831 Views)
Same here.  Only UIR.  Some of my projects have dlls, but never Active X.
Message 28 of 49
(3,764 Views)
Can you try samples\userint\activex\WebBrowser.csw example to see if the same hang happens.
You could put a breakpoint for example on Refresh() callback. Run the program and push the refresh button, the breakpoint should be hit. See if continuing execution the same hang happens.
Constantin
Message 29 of 49
(3,749 Views)
Hello Constantin,
I tried this example and set a breakpoint in the line void CVICALLBACK Refresh(...) as you suggested.
After stepping into the function
INET_IWebBrowser2Refresh (webHandle, NULL);
with F8, I went on a while stepping through with F10. No Problem. Then I tried to continue the program with F5 and then the program hangs.
I had to cancel the cvidebugger in the task manager and then the already known merror message pops up:
"LabWindows/CVI did not receive a reply to a debugging message"
So this might be a project/source with the reproducible error?!
Best regards and greetings for a happy new year.
Gunther
Message 30 of 49
(3,743 Views)
