LabWindows/CVI
Default directory in FileSelectPopup
I'm using 19.0.0
Message 11 of 13
(587 Views)
I've tested it with CVI 2012 SP1, 2015 SP1f1 and 2017 (17.0.0): the behavior I see is consistent across all versions.
Message 12 of 13
(576 Views)
Roberto,
I'm using CVI 2019 version 19.0.0 on Win10 --
FileSelectPopup (and FileSelectPopup Ex) always default to the last used path no matter what I set for the defaultFileSpec parameter. This holds even through pc reboots.  Is this a Win10 issue? Is there a workaround?
Message 13 of 13
(514 Views)
