LabWindows/CVI
Default path for distribution kit
Hi Steve,
Creating a merge module from scratch in Orca is not particularly easy, so I created one for you using Wise for Windows Installer.  You can still edit this .msm in Orca to your heart's delight.  The significant entries are in the CustomAction, ModuleInstallExecuteSequence, and ModuleInstallUISequence tables.  The CustomAction table defines an action CA_SetDirectory_INSTALLDIR that sets the INSTALLDIR property (this is the default installation path that is displayed) to "R:\StationSoftware".  The module sequence tables define at which point in the installation this custom action should be run.
To merge the module into your distribution, create a file group named _MSMs_ and add the .msm file to the group.  When you build the distribution kit, the module will be merged in.
Keep in mind that this new path is hardcoded.  You will need to edit the .msm file (change the Target column of the CustomAction table entry) to make any changes.  Also, if you try to run the installer on a machine without an R: drive, you will get an Invalid Drive error that will cause the installation to fail.
I hope this solution works out for you.
Mert A.
Message Edited by Mert A. on 08-10-2006 12:34 PM
Message 11 of 11
(1,096 Views)
