LabWindows/CVI
Define Macro with sprintf Help
Hi Im using a define macro , Im trying to format a string  a certain way  in the Error check macro im creating.
 This is what I have so far, and it works.
#define ERROR_CHECK(fCall,iErrorNumber)if(iStatusCheck=(fCall),iStatusCheck<0)\
{iStatusCheck=iErrorNumber;goto ErrorCondition;} else
ERROR_CHECK(ChillerTemp(Temp),InvalidTemp);
But Now I want to be able to add another parameter with a format of  a sprintf, can you assist me, Let me give you and example of what im trying to do below
Im trying to find a certain way to include this sprintf in another parameter in my define macro. Im cutting everything down to one line of code .
sprintf(mErrorData.errMsg,"F%d:ERROR:Chiller Temperature",CHILLER_EXECUTE);------ im trying to include this line in the define macro, can you give some me assistance
mErrorData.errCode = errorFlag;
so do i do something like this below,
ERROR_CHECK(ChillerTemp(Temp),sprintf(mErrorData.errMsg,"F%d:ERROR:Chiller Temperature",CHILLER_EXECUTE));  -------- do you think this will work
and if this works, how would I include this line of in the macro  after receiving the error  ------- mErrorData.errCode = errorFlag;
I ask that because when i go to quit , Im doing a check against  mErrorData.errCode!=pass
    QUIT://escape destination
    if(mErrorData.errCode != PASS)
        errorFlag = FGEUBIT_EXECUTE;
    return(errorFlag);
(6,279 Views)
actually this line is taking care of  below, I just need to see how im going to use the sprintf
(6,275 Views)
Hi I think should work, Im getting ready to go test it in a hour, Im just writing everything down on paper first,
So im going to try this, Let me know if you think this will work below
#define ERROR_CHECK(fCall,iErrorNumber)if(mErrorData.errCode=(fCall),mErrorData.errCode<0)\
{mErrorData.errCode=iErrorNumber; eAgent->LogError(&mErrorData);goto ErrorCondition;} else
(6,266 Views)
I don't think you will get the result you are looking for. sprinf() returns the number of ASCII characters processed - are you expecting an error code?
JR
Message Edited by jr_2005 on 04-12-2010 03:50 PM
(6,262 Views)
#define GEU_ERROR_AGENT(fCall,iErrorFlag,sStrPointer)if(mErrorData.errCode=(fCall),mErrorData.errCode!=PASS)\
{mErrorData.errCode=errorFlag;sprintf(mErrorData.errMsg, "F%d:ERROR :%s:",errorFlag,sStrPointer);,eAgent->LogError(&mErrorData);goto QUIT;}
ok this is the function im expecting pass or fail  below  , pass = 0 , and fail = 1 or any number  but 0.
errorFlag -getChillerTemp()->execute("_ChillerTemp", Temp);
so im trying to embed this in my define macro
 which is
GEU_ERROR_AGENT( getChillerTemp()->execute("_ChillerTemp", Temp),FCHILLER_EXECUTE,"getChillerTemp");  ///////// for some reason when I use the define macro, its failing and should  not fail because when I put it the nornal way below its passes
Normal Way:  this passes below, but when i switch to the define macro it fails some odd reason
if((errorFlag = getChillerTemp()->execute("_ChillerTemp", Temp)) != PASS)
          sprintf(mErrorData.errMsg, "F%d:ERROR:getChillerTemp",errorFlag);
          goto QUIT:
      errorFlag = FCHILLER_EXECUTE;
return  errorFlag;
(6,217 Views)
These might be typos, but you have some inconsistencies within your macro. For instance, you have a macro parameter iErrorFlag which is not used within the macro body, but you do have a (integer?) errorFlag which does not appear to be altered. Are these supposed to be the same?
Before spending too much time on analysis, it is best to start with known code that is copied and pasted from the original C source, rather than simply being re-typed into this forum.
JR
(6,215 Views)
Sorry about that, this is the correct info below
errorFlag =getChillerTemp()->execute("_ChillerTemp", Temp);
          goto QUIT:
return  errorFlag;
(6,199 Views)
