LabWindows/CVI
Delaunay triangulation function
I'm looking for the Delaunay triangulation function in CVI but couldn't find it. Did I miss it or is yhis function not available in CVI.
I found some results for Labview but not CVI. Is it possible to use the Labview implementation in CVI?
(3,020 Views)
Hello Bertrand_ENAC,
I think you have 2 different solutions to achieve your goal.
  1. If you want to use specifically the LabVIEW function, you can create a DLL using this function from LabVIEW, and then use it in LabWindows/CVI.
  2. You can find an open-source mathematic library containing an implementation of Delaunay triangulation and use it in your code.
Regards
(2,960 Views)
Hello @Bertrand_ENAC,
based on my experience, when you have this kind of needs in CVI the best option is searching a third-party library that fulfills your requirements and wrap it into a CVI project.
Usually the most difficult thing is to find a library written in plain-C clang-compliant.
If you use one of the lastes CVI release (2015 or newer) the integration is easier (usually).
I don't know if this is ok for you but this site seems to point to a couple of C source files to do this kind of triangulation.
Vix
In claris non fit interpretatio
Using LV from 7
Using LW/CVI from 6.0
(2,954 Views)
