LabWindows/CVI
Delay smaller then 1ms
The code I posted will compile and run in CVI.  The sample code is part of a utilities library (DLL).
This code below works fine for me.
Iam running CVI 7.1 on Windows XP.
#include <ansi_c.h>
#include <stdio.h>
int main()
 __int64 a = 0;
 __int64 b = 0;
 a = 3;
 a = a << 1;
 printf("a: %I64d\n",a);
 b = 2;
 b = a - b;
 printf("b: %I64d\n",b);
 return 0;
Message 11 of 36
(2,757 Views)
Thanks.
Looks like it's a CVI 8.0.1 problem.
I fired up a copy of CVI 7.1 and it works fine as you said.
What stupidity, I've wasted so many hours on this ...
Menchar
Message 12 of 36
(2,747 Views)
The problem turns out to be the use of the static storage classifier (heap) on a LARGE_INTEGER.
This code fails with a GPF:
static LARGE_INTEGER lia;
          LARGE_INTEGER lib;
Message 13 of 36
(2,738 Views)
          LARGE_INTEGER lib;
Message 14 of 36
(2,739 Views)
          LARGE_INTEGER lib;
Message 15 of 36
(2,739 Views)
          LARGE_INTEGER lib;
Message 16 of 36
(2,736 Views)
          LARGE_INTEGER lib;
Message 17 of 36
(2,736 Views)
          LARGE_INTEGER lib;
Message 18 of 36
(2,736 Views)
          LARGE_INTEGER lib;
Message 19 of 36
(2,736 Views)
          LARGE_INTEGER lib;
Message 20 of 36
(2,736 Views)
