LabWindows/CVI
Deleting panels from a UIR.
I have a UIR which contains multiple panels. Several of these panels are now obsolete. I'm sure this is a fairly rudimentary question but I can't figure out how to delete a panel out of the .uir file. Any help would be appreciated. Thanks.
(3,188 Views)
Hello ejv11,
We do not allow you to delete a panel with the Delete key in order to make it harder to accidently delete a panel and significantly break your application. So, first click on the panel you would like to remove in the UIR editor window . Then click Ctrl-Shift-X or navigate to Edit >> Cut Panel.
Wendy L
LabWindows/CVI Developer Newsletter
(3,184 Views)
