LabWindows/CVI
Dependent projects in CVI 2010 SP1
From CVI 2015 I can see the item Build >> Project dependencies... that I use when I get multiple projects in the same workspace, and I want to manage the dependecies between the projects themselves.
As an exmaple Project A depends on Project B (and so Project B must be built before Project A).
In CVI 2010 SP1 I can't see that item and so I don't know how to handle the dependencies between two projects in the same workspace.
Is there a way?
Vix
In claris non fit interpretatio
Using LV from 7
Using LW/CVI from 6.0
Message 1 of 1
(1,061 Views)
