LabWindows/CVI
'Designated Inits' in CVI 2015 SP1
This document says that CVI 2015 support 'Designated Inits' with warning.
Using CVI 2015 SP1 this instruction
namespaceArray->value.dataSource = (UA_DataSource) {.handle = server, .read = readNamespaces,
                                                        .write = NULL};
doesn't give any warning and compiles fine, but while executing it produces a 'General Protection' fault.
I suspect this is related to the usage of 'Designated Inits' to set the members of UA_DataSource struct.
Could someone investigate this behavior?
You can see the error trying to run this example from open62541 library (OPC UA).
Vix
In claris non fit interpretatio
Using LV from 7
Using LW/CVI from 6.0
(6,432 Views)
Hello vix,
I tried to run the example but I could not do it.
Please could you post here the screenshot of the error you are getting running this example?
Thank you!
Giuseppe
(6,399 Views)
I forwarded a working example to NI support engineer with a ticket number #2706258
Vix
Using LV from 7
(6,396 Views)
This seems a bug.
NI support opened CAR ID 618185.
Vix
Using LV from 7
(6,353 Views)
I confirm that the CAR is actually under investigation.
Licia
(6,320 Views)
I've been meaning to try this code in CVI for a while.
The problem is with the line bellow and 4 more like it. It builds but gives you a general protection fail when run:-
namespaceArray->value.dataSource = (UA_DataSource) {.handle = server, .read = readNamespaces, .write = NULL};
If you alter the line to add an interim stage (all 5 instances) then it builds and runs perfectly.
UA_DataSource dtemp = {.handle = server, .read = readNamespaces, .write = NULL};
namespaceArray->value.dataSource = dtemp;
Hope this is some help.
Cheers
(6,022 Views)
Hey Vix,
This bug is related to user protection when a structure field of a union contains a pointer and was created with a designated initializer. Aside from initializing the struct first, setting the Debugging Level to "No run-time checking" in the build options should prevent the GPF.
This should be fixed in future versions.
Have a good one!
Trent
https://www.linkedin.com/in/trentweaver
(5,843 Views)
