LabWindows/CVI
Detect Modifier keypress
I would like to detect if a modifier key (shift, ctrl) is pressed when I click on a control. Given that the EVENT_KEYPRESS is only fired when I press a normal key on the keyboard, how can I do it?
Thank you for you help
Bertrand
Message 1 of 8
(6,183 Views)
Hello Bertrand.
Have a look at the GetGlobalMouseState() function (from the User Interface Library). Here is the prototype:
int GetGlobalMouseState (int *panelHandle, int *xCoordinate, int *yCoordinate, int *leftButtonDown, int *rightButtonDown, int *keyModifiers);
Within your control callback, examine the value of keyModifiers. From the control help in the function panel:
"State of the keyboard modifiers, in other words, the <Ctrl> and <Shift> keys.
If no keys are down, the value is 0. Otherwise, the value is the bitwise OR of the appropriate key masks: VAL_MENUKEY_MODIFIER and VAL_SHIFT_MODIFIER.
You can pass NULL."
Colin.
Message 2 of 8
(6,178 Views)
Thank you. I would never have had the idea to look at the mouse state to get the modifier key.
Bertrand
Message 3 of 8
(6,145 Views)
Please Help me out this.
in my application i did two button UP and DOWN.
if i press UP button my object will move up direction same if i press DOWN my object will move down.
here i want i will press continues UP button my object will move contuesly,i tired  alot is it possible in cvi 5.5.
Message 4 of 8
(5,544 Views)
Maybe something like that should work.
int CVICALLBACK ButtonUp (int panel, int control, int event,
        void *callbackData, int eventData1, int eventData2)
{int LeftBtDown;
 switch (event)
     case EVENT_LEFT_CLICK:
        LeftBtDown = 1;
        while (LeftBtDown==1)
            /*==== Move Object ===*/
            // Code for moving object
            GetRelativeMouseState (panelHandle, 0, 0, 0, &LeftBtDown, NULL, NULL);
        break;
 return 0;
Message 5 of 8
(5,537 Views)
okay thank you i will try this
Message 6 of 8
(5,533 Views)
thak you sir its working
Message 7 of 8
(5,512 Views)
Hello Sir,
this code working fine with my machine,now machine will go up down w.r.t my up/down key press, but my while loop causing prob if im using up or down button my othr funtion not updating,in my code  evry .001 sec my one function running....if im using up/down button my other function not executing parrally.....
how to solve this ...shall i use timer intsted of while?.
Thank you in Advance
sudhir
Message 8 of 8
(5,464 Views)
