LabWindows/CVI
Determine number of channels on a DAQ card
Is there a function to determine the number of channels on a given DAQ card?
(3,133 Views)
I found no native function to get this attribute; you can use DAQmxGetDeviceAttribute with DAQmx_Dev_AI_PhysicalChans attribute to get a list of available channels on a device and then parse the string counting channels. The following lines can be executed in the Interactive Execution window: provided the device name is correct they count how many input channels are present on the board:
#include <ansi_c.h>
#include <utility.h>
#include <NIDAQmx.h>
static int		i;
static char	msg[512];
static char	*token;
DAQmxGetDeviceAttribute ("Dev1", DAQmx_Dev_AI_PhysicalChans, msg, 512);
i = 0; token = strtok (msg, ",");
while (token) {
	i++;
	token = strtok (NULL, ",");
DebugPrintf ("# of channels: %d\n", i);
 The same function has equivalent attributes for analog outputs, counters and digital I/O lines / ports.
(3,123 Views)
