LabWindows/CVI
Determining if any popup panels are active
I have looked through the user interface library and have not found anything obvious... Is there any way to determine if a popup panel is active?
I have a situation where I may get an abort message from an external souce that would shut down the test sequence in progress. When this message arrives, I would like to close any active popups and display the abort status.
Just doing a RemovePopup(1) call gives an error, I only want to call it if there is an active popup.
I could do something like this:
   SetBreakOnLibraryErrors (0);
   RemovePopup (1);
   SetBreakOnLibraryErrors (1);
But I really prefer to avoid such shnanigans.
Martin Fredrickson
Test Engineer
Northrop Grumman
Advanced Systems and Products
San Diego, CA 92128
(3,367 Views)
Hi, MJF.
There are a couple of ways to do this. You could use GetActivePanel() to find out which panel is active, or you could use GetPanelAttribute() with the attribute ATTR_ACTIVE.
Heres the definition from the CVI help:
ATTR_ACTIVE
Type: Panel attribute
Description: Indicates whether the panel or one of its child panels is the active panel.
0 = Panel not active
1 = Panel active
Restrictions: Not settable.
Data Type: integer
Let me know if you have any more questions. Have a nice evening.
Sarah K.
Search PME
(3,348 Views)
Ah well, I was afraid somebody was going to say something like that. I was hoping for something very simple like a single function call that returns a 1 if there are active popups and 0 if not.
I'd see this as a nice feature to have in future, could we get it as a feature request for a future release?
Martin Fredrickson
Test Engineer
Northrop Grumman
San Diego, CA 92128
(3,323 Views)
Hi Martin,
I recommend submitting Product Suggeston for this feature.  This is a great way to let R&D know what features would make a big difference for you.
Best Regards,
Megan B.
(3,296 Views)
