04-03-2018 08:04 AM
I have search the site but can’t find what I am looking for and also using 2011 version (works great for other apps written). Also using a new USB-6509 DAQ unit which seems to work nice.
This project is for a wiring harness tester with multi wires, up to 90+.
The design seems simple (but will be long), can't do looping as far as I can tell.
Line 1 goes high and then you check all other lines for a high.
Next pass, Wire 2 High and you check Pins 1 & 3,4,5 etc.
And so on with only 1 pin high at a time and reading input pins that SHOULD NOT BE HIGH.
I have input ½ of it working but the Output High pin keeps going low once it starts the File Sequence.
Can’t figure what I’m doing wrong.
04-04-2018 06:02 PM
I have a few clarifying questions.
