LabWindows/CVI
Dimmed buttons delay but do not disable a button click .
When I push button A on the main panel I want it to disable several other buttons also on the main panel. I am trying to accomplish this by dimming the buttons at the beginning of button A's callback function and then restoring the buttons at the end of buttons A's callback. The problem I encounter is that when a dimmed button is pressed it's callback is queued up and once the button is un-dimmed the queued callbacks are run. In contrast, I would prefer that when a dimmed button is clicked this mouse click is just completely ignored and the callback from this click is never run. Does anyone know how to accomplish this?
Also, I am trying to dim items from a menu bar using SetCtrlAttribute and ATTR_DIMMED(the same way I'm dimming the control buttons) but am not having any success. Is it possible to dynamically dim menu bar items?
(5,098 Views)
Call ProcessSystemEvents() at the end of the callback for button A before undimming button B.
The behavior you describe is related to the way CVI and Windows process events that occur during callbacks. CVI does not process events that occur during a callback, unless you call ProcessSystemEvents. So when, in you callback for button A, you dim button B then press button B, that event is queued but not processed. Then you undim button B and return from button A callback. Now CVI is ready to process the click on button B. Button B is no longer dimmed so the callback for button B is executed.
When you call ProcessSystemEvents in callback A before undimming B, it forces CVI to process events (like the click on button B) that occured during the callback for button A. Since button B is dimmed, the click will be processed and ignored.
(5,085 Views)
...and to disable menu items use SetMenuBarAttribute (menuBar, menuItem, ATTR_DIMMED, 1);
(5,080 Views)
P.S.: Also in a callback, CVI doesn't process draw events (like drawing the buttons dimmed), so you may want to call ProcessDrawEvents() immediately after dimming button B in callback A so button B looks disabled.
(5,079 Views)
Here's a quick example that shows you the behavior with and without calling ProcessSystemEvents.
(5,077 Views)
Have you tried
SetCtrlAttribute (panel, PANEL_BUTTON, ATTR_VISIBLE, 0);
Bye
(5,068 Views)
Thanks to everyone for the replies. I implemented the suggestions and everything is working exactly as I would want.
(5,064 Views)
