LabWindows/CVI
Direct Port IO
I have a Bluchip PIO-48 board which consists
of 2 8255 I/O chips I/O mapped at 0x300 (PORTA)
etc.
I have set the ports to Inputs but I'm gettting
weird results with byte = inp (PORTA) instructions.
Does anyone have any experience of using these
boards or with using the inp() functions for
direct IO ?
Cheers"
(4,455 Views)
I have not used BlueChip boards but have done direct IO using inp & outp
without any problems. This was using computerboards ISA based DIO cards
under NT 4.0. What OS you are using? Make usre address 0x300 is available on
your PC. Are input lines tied to +ve or GND?
vishi
"DerekG" wrote in message
news:506500000008000000F96A0000-1031838699000@exchange.ni.com...
> Hi,
> etc.
> direct IO ?
> Cheers"
(4,454 Views)
Cheers for the reply.
I am using Win95 (I've tried Win2K too).
I know 0x300 is OK cause I wrote a DOS program to
sample the ports and this works OK in a window
under WIN95.
DG
(4,454 Views)
Try puting the port in output mode. That way when you write a bit pattern
youc an easily see with a DMM.
BTW - What kind of error you having when you use the port in input mode? I
am no hardware guy but I think for input mode, the lines need to be tied to
+ve or GND, otherwise they are floating, unless the equipment you are
connection to explicitly gives high or low.
vishi
news:5065000000050000004ABE0000-1031838699000@exchange.ni.com...
> under WIN95.
> DG
(4,454 Views)
Yeah, tried that no good. It's like the card isn't
there. But it works OK via my DOS program.
I'm not getting an error as such, just random data
values for port = inp(PORT) when all are tied
to either gnd or vcc.
(4,454 Views)
Possibly, Parallel Port Central at http://www.lvr.com/parport.htm might have the
answer.
(4,454 Views)
