LabWindows/CVI
DirectInput with LabWindows/CVI
I'm trying to use DirectInput to get position data from a USB joystick in LabWindows/CVI. CVI 2013 comes with the headers and libs for direct input in its sdk subfolder, and the DirectX SDK comes with a really simple example.
However, already the first step of opening creating a directinput handle fails to compile - this is basically copied verbatim from the directInput documentation or the joystick example provided with the DirectX SDK.
#include <ansi_c.h>
#define DIRECTINPUT_VERSION 0x0800
#include "dinput.h"
int main (int argc, char *argv[])
LPDIRECTINPUT8 di;
HRESULT hr;
hr = hr = DirectInput8Create( GetModuleHandle( NULL ), DIRECTINPUT_VERSION, IID_IDirectInput8, ( VOID** )&di, NULL );
return 0;
60, 42 error: passing 'const GUID' (aka 'const struct _GUID') to parameter of incompatible type 'const IID *' (aka 'const struct _GUID *')
18, 1 In file included from c:\Users\tpaprotta\Documents\National Instruments\CVI\Command-line Application.c:18:
"dinput.h"(2682,83) c:\program files (x86)\national instruments\cvi2013\sdk\include\dinput.h:2682:83: note: passing argument to parameter 'riidltf' here
The same code compiles without issues under Visual Studio 2012.
(6,298 Views)
Greetings,
I assume you mean works in LabWindows/CVI 2012? Also, do you have the latest patch for CVI 2013?
Brandon V.
(6,253 Views)
Hi Brendan, I just updated to CVI2013SP1, and it doesn't make a difference, I get the same error message - it's basically just the first line opening a session, verbatim from the Microsoft DirectX example. It does compile with VisualStudio 2012, as mention above, that was not a typo.
(6,086 Views)
It looks like this example may have been written for C++ instead of C. This might be why it runs in Visual Studio and not CVI. Can you investigate this?
Brandon V.
(6,020 Views)
Accepted by topic author atomcooler
So there is / was a number of issues. Yes, the example in question is C++, so instead of calling
one has to call
DirectInput8Create( GetModuleHandle( NULL ), DIRECTINPUT_VERSION, &IID_IDirectInput8, ( VOID** )&di, NULL );
(IID_IDirectInput8 is defined differently depending on whether C or C++ invokes it).
However, if one makes that change, the symbol _IID_IDirectInput8 can't be found. The symbol is not in dinput8.lib (which is included with CVI), but rather in dxguid.lib (which I couldn't find in the NI folders). It is distributed with the DirectX SDK - so I'm linking against that now. I'm curious, however, why NI would distribute dinput8.lib / dll and not other requisite libraries, which seem to be needed to use them.
(6,014 Views)
