LabWindows/CVI
Discrepancies between system() and LaunchExecutableEx()
I'm attempting to replace a call to system() with LaunchExecutableEx to allow for more control over window appearance. The application I am calling is sending some SNMP commands. I eventually send the same commands, using the same function, to a remote client and to localhost. The actual calls to the executable contain a LOT of arguments; Paths, tokens, IP addresses...
However, the ones sent to localhost never make it to the listening server I've setup. But, ONLY if I'm using LaunchExec... it works just fine with system...
LaunchExec... returns a valid handle, and no errors. I've renamed the executable during runtime and made sure it was throwing errors, and it is.
I does this ont he first call to LaunchExec... so I'm sure it's nothing to do with the number of processhandles being made.
 Anyone else ever have this issue?
(3,765 Views)
Hey Crymsenn,
What are you passing in as your arguments to LaunchExecutableEx? Also, have you tried using your local IP address instead of using localhost?
Lars
(3,727 Views)
