LabWindows/CVI
Display Release Version and Date in Programm
Hi all,
is it possible to get the Release Version and Release Date Information, which will be build by the Release Builder, and display it in a programm? Or is there just the possibility to read the information out of a file, for example the generated setup.ini.
I don't like to use the setup.ini solution, because I have to copy another file and it's very easy to manipulate.
Thanks for your help!
(3,639 Views)
Hi Marco,
you can read how to do this at this link.  It is a knowledgebase entry at our website 'Determining the Version of an Executable Built with LabVIEW'.
Regards
TomBaum
(3,607 Views)
This example may be of help:
http://zone.ni.com/devzone/cda/epd/p/id/1975
(3,578 Views)
