LabWindows/CVI
Display a number in hex in C++
Let say I have:
char car=0xE2;
char str[10];
How do I put this value in string?
If I try:
sprintf(str,"%#x",car);
the result will be: 0xffffffe2
But I want to display only 0xe2.
How should I do it?
Thanks a lot
(4,014 Views)
Try :
sprintf(str,"%#x",(unsigned char)car);
B.W.
(4,011 Views)
being pointy-haired as i am, i would say that using sprintf() is not C++ !
(3,959 Views)
As LabWindows/CVI is an environment based on ANSI C, the aforementioned approach might actually be best and a consideration for C++ could be considered out of context.
(3,918 Views)
a consideration for C++ is indeed out of context... i was just pointing out the obvious error in the title of the thread.
(3,911 Views)
