LabWindows/CVI
DisplayPanel() doesn't display window
I'm using this function to display a panel from a menu bar.
void CVICALLBACK aff_data (int menuBar, int menuItem, void *callbackData,int panel)
   DisplayPanel(data_login_handle);
The function is working well with french and english version of windows XP but does absolutely nothing with korean and japanese version of windows XP (the panel doesn't show up).  I use DisplayPanel() successfully somewhere else in the code for other panels.
What should I check to debug this kind of behavior ?  Any clues would be very appreciated.
(3,598 Views)
Sorry to be so trivial, did you try to add ProcessSystemEvents after the DisplayPanel intruction ?
ProcessSystemEvents ();
(3,577 Views)
Hello Gich,
You mentioned that the DisplayPanel works in the rest of your program, so I'm not sure if it is an OS language specific problem.  I notice that the callback is actually a menu callback, after adding a call to ProcessSystemEvents as dilution suggested, does the problem still occur?  I would also make sure that the handle you pass into DisplayPanel is valid.  Also, which version of CVI are you using?
Thanks.
Wendy L
LabWindows/CVI Developer Newsletter
(3,563 Views)
