LabWindows/CVI
Displaying 2 digit year
  I need to display the date and time from a string of data I have of hex numbers(hh:mm:ss  mm/dd/yy).  I received each section of the data in an integer array.  The problem is that when any of the data is less than 10, it only displays it as 5 for example.  Where as I need it to display 05, I assume this is possible but not sure how.
// Update Read Time
sprintf(ctemp,"%d:%d:%d  %d/%d/%d",RxPacket[6],RxPacket[7],RxPacket[8],RxPacket[4],RxPacket[3],RxPacket[5]);
Thanks.
(3,140 Views)
  I found the answer I kept only putting %2d, but I needed to put %2.2d.
(3,136 Views)
