LabWindows/CVI
Distributing App. with USB-6501as start device
I have two applications which I would like to use the USB-6501 as a remote start device.  Very simple; pulling one of the digital inputs LOW starts the data collection program.  A 2nd input stops the data collection.
What is required as drivers to sell the USB-6501 along with the software?  I want to customer to have a minimal install configuration, and prefererably, the drivers for the 6501 would would install with my software.
Thanks in advance, David Eaton
(3,428 Views)
Thank you for posting to the NI Forums! The NI-DAQmx driver is needed for the 6501. If you build an installer in LabVIEW, you can choose to include the NI-DAQmx and the LabVIEW run-time engine for the version of LabVIEW you are using. Hope this helps!
Margaret Barrett
Digital Multimeters and LCR Meters
(3,397 Views)
