LabWindows/CVI
Distribution Kit and Installation Question
I have an app that I built with LabWindows/CVI 2009.  I also built a distribution kit for it.
How can I indicate in my distribution kit that I want to be able to install the same version or an earlier version over an existing version?  My customers in the field may need to "repair" a corrupt file by reinstalling a version "over itself".
Thank you.
(4,876 Views)
(4,850 Views)
I would not recommend the "side-by-side" option in this case.
I think that the simplest solution is to tell them to uninstall and then reinstall in the rare cases where a corrupt file needs to be fixed, but that is probably how the issue is addressed now.
Based on my experiences here  (last half of that thread was hijacked for a separate topic) I doubt you will be able to change a setting to do a "repair" installation, but NI staff should be able to provide a solid answer.
--Ian
(4,797 Views)
