LabWindows/CVI
Distribution Kit error for Program Files directory
I have created an install setup for my program with CVI 6.0 Distribution Kit. When I installed my program, the setup created the folder E:\ProgramFilesFolder\ instead of using D:\Program Files which already exists. The behavior is the same when creating a shortcut on the desktop. How can I install my program in the correct directory ?
Several things I have done with no success :
1 - Copy my project to 😧 and rebuild distribution kit
2 - Check Windows registry for ProgramFilesDir
Thanks in advance.
Bertrand
(3,069 Views)
Hello
This is probably happening because CVI uses the default MSI ( Microsoft Installer) logic, which is to select the root drive as the drive with the most space. Im assuming in your case you have multiple drives and that E: probably has more space. You can work around this by forcing the install to the correct folder by using the msi command line parameters, as follows
setup.exe INSTALLDIR=C:\MyDir\foo
Let me know if I missed anything.
Bilal Durrani
NI
Bilal Durrani
NI
(3,069 Views)
